steering column mount
Started by buggysam, May 10, 2013, 09:46:25 PM
buggysam
What set up have you used for steering column mounts?
will be rebuilding my buggy front end over the winter time and uprating the steering supports, So any advice, pics and measurements as to what you have on your buggy would be great!!
Sam
72 Sidewinder, 04 seat Leon Cupra R.
parmaynu
Nuffin
I've got a Berrien column support. No pics unfortunately. It's not installed at the moment. You could borrow it to have a copy fab'd up if you like.
Old Skool Parts Shop
oldskoolpartsshop.com
buggysam
Thanks mate you have PM
Sam
buggysam
anyone else got any information please or pics
Here's the bracket I made for my newbuild out of steel strip, water pipe and an exhaust clamp. It's solid, it works really well.
Hazel
mk1 GP
buggysam
Thanks All,
David, does that system flex at all? I have the same style I my buggy at the moment, Its made from an oval tube across the car, with a single fixing point to either side.
Would it be better made with box section or tube instead of the oval???
The play seems to be in the oval tube as when we wedged a bit of wood from the top of the gearbox tunnel to the cross bar the play was illiminated.
Any more pics or suggestions
Sam
You could always stiffen it by welding a length of flat bar along it like Berrien do..
colGT
GT
Hey Sam
I used a flatlands mount - tried to get some pictures in my blog - link below.
Your more than welcome to come and have a poke around if it would help?
Give me a shout.
#9
1 length of 30 x 30 thin wall tube, 2 bits of clutch cable conduit, and 4 pieces of 2.5mm thick Zintec sheet....
Job done  ;-)up
