Hewland Conversion
Started by Sandrailer, May 08, 2013, 08:04:55 PM
Sandrailer
Sand Rail / Buggy
Hi Guys
As some of you know, i own a Beetle chassis that was converted to run a Ford CVH engine. I am stripping it as I want to run VW.
Do any of you know what the details of the conversion are? I am looking to sell it all on, but have no idea on what it is worth etc....
There seems to be
2 x Engine Support brackets
1 x Bell Housing adapter
1 x Gearbox with longer shaft
1 x Shorter gearbox linkage shaft (from gear stick to box)
Pics as follows:
Any info would be great
Ta
In the Process of collecting parts for a Sand Rail Buggy. '67 Chassis and New frame under construction
buggypete
that will be an old formula ford set up.works great but the starter is an old  ford style lump and gets in the way.can be used for the kent engines as  well.cheap n chearfull engine supply
