Shopping list for Tatton Park
Started by Manxdavid, July 28, 2021, 01:04:48 PM
1x Sprintstar wheel, 5 1/2 wide deep dish, also Sprintstar centre caps.
RHD pedal assy (Steve Saville?).
Any missing pedal bits for above.
RHD Pitman arm.
Flanges for steering box and column.
Nap's hat.
Formuling France steering wheel centre.
Any interesting/cheap shifters.
Small SunPro etc column mount tacho.
Etc, etc, etc....
Oojamiflip has your wheel from down here.
I was going to message you to make sure you still wanted the pedals. They are already in the buggy.  I'll be on the buggy club stand.
Quote from: Buggybaggy on July 28, 2021, 03:57:05 PM
Any good for you?
Do you know what year it's off? I need a 69 on one for larger rod ends. Ta.
Earlier as far as I know. Do you know the rod end bore sizes?
Thats an early arm for K&l with no steering stops so small ball joints, 67 had small joints and the later smaller box shaft with steering stops, 68 on had the smaller shaft and larger joints with steering stops.
I'll pass then thanks, I've got the rod ends already.
buggypete
Should have pitman arms,got a new napolians hat,some shifters,etc
Quote from: buggypete on July 29, 2021, 07:51:20 AM
I'll see you Sunday ☺️
Oojamaflip
Californian
Quote from: snoopy on July 28, 2021, 02:13:36 PM
Do I ??
Kango T top
SWB Girlfriend
parmaynu
Nuffin
Any good for you?
How much would you like for the pitman arm?
Old Skool Parts Shop
oldskoolpartsshop.com
Oojamaflip
Californian
Quote from: Manxdavid on July 29, 2021, 05:52:33 PM
Quote from: Oojamaflip on July 29, 2021, 03:47:24 PM
Do I ??
Do you?!🤔
No but we found it brooksters got it so it will be there
Kango T top
SWB Girlfriend
