Type 4 webers or dellorto's wanted
Started by Chris M, April 13, 2021, 07:14:03 PM
I'm after a set of either weber 40 IDF's or Dellorto 36DRLA's for a type 4 motor build. Looking for the whole lot, manifolds and linkage ideally but will be open to either carbs or manifolds as separates. Let me know what you have.
I'll also be needing an exhaust for it too so looking for a side winder type system if you happen to see any hen's teeth.........................
Thanks Chris.
