speedo cable routing in sidewinder
Started by jodieshann, April 27, 2013, 06:32:18 PM
jodieshann
Hi chaps,
got a sidewinder (LHD) with a speedo located over on the passenger side. need to get the cable routed from the speedo over to the left hand side hub. any ideas how? can't see anywhere in the tub that it can pass through to under the car? do i need to drill a hole? there was a speedo fitted before i had the car but it wasn't fitted when i got it. i can't see anywhere for the life of me that it could have gone? cable looks too short to me too but that's another matter!
thanks all
You'll need to drill a hole in the bulkhead for the cable to pass through. Just make sure the petol tank isn't in the way if you're drilling from the inside. Mine's a LHD with the speedo in the middle and I used a LHD cable as it's shorter. Make sure you've got a RHD cable as you'll need the extra length.
