Size of Manx screen
Started by grissley, July 17, 2019, 07:56:41 PM
grissley
What's the i/s frame arms dimensions and also the frame cross section width I, m guessing it's maybe 35/40mm? Also depth of groove where hood clips inside.
The width of the scuttle where it mounts, therefore the width across the inside of the frame arms is 42 1/2 inches, sorry, I don't know what that measures in French. Standard height for a Manx screen is 16 inches.
I'll get the other dimensions tomorrow, its lashing down now!
grissley
Still need width of aluminium extrusion and groove size please
grissley
Cheers dave,
They won't fit an ff then
Roadrunner
FF LWB
#6
Quote from: grissley on July 22, 2019, 09:37:38 PM
Cheers dave,
Grissley. They will fit an FF I have one on mine
grissley
The bottom of the screen bar must be smaller section than the side and top then??.
To fit in front of the dash lip, what width is the bottom screen section then?
Roadrunner
FF LWB
Yes the bottom of the screen is smaller.  You have to mount it groove in otherwise it doesn't fit round the lip of the bonnet/dash join
grissley
