Steering column parts
Started by Paul1953, June 08, 2018, 01:41:27 PM
A real long shot here I guess. Does anyone have, going spare, the small section of the steering ignition\lock assembly shroud. (Plastic shroud version). This is the piece  that covers the lock top area and the gap in the main shroud on the ignition switch side. (Donor Beetle didn`t have this piece present).
I can`t quite tell how this missing piece secures to the shroud itself. May just be a push in fit. (The earlier metal versions are held in place with two screws). Here`s hoping. ;-)up ;-)up
