HELP
Started by Paul1953, November 29, 2017, 01:45:45 PM
Does anyone have a original set of "flange connectors" that go either side of the flexi ring on the steering column shaft... the collapsible section spline end and the steering box spline end. I have bought repo ones. Chromed rubbish that will not allow a clamping bolt through. No meat on the bolt hole area to widen it and I`m not grinding the shaft recess. (Box is repo unit also).
The two repo bits are chromed.... well that`s what it`s described as. Thin as I don`t know what.
