Dual 36idf Weber setup
Started by targed, October 05, 2017, 09:42:25 PM
targed
Pair of Italian 36idf Weber's, with filters, new empi manifolds and a centre pull linkage.
I picked these up a few years ago, with the intention of fittingthem to my bay, but never got round to it, and frankly probably never will....
The Weber's are genuine Italian ones, that I fitted an overhaul kit to. Nothing obviously wrong with them, but I've never run them, and they've sat gathering dust in my garage now for at least 5 years, so I would suggest going through them again to make sure you are happy with them.
New empi manifolds that have been lightly port matched to a stock 1600 twin port head. Never been fitted to an engine.
Centre pull linkage, that I assemble from bits I had kicking around. May require the rods modifying slightly as I never used it with these manifolds.
I have quite a lot of Weber jets, so can probably jet these close enough to get you started if you let me know your engine spec.
£350
targed
