B -rookie Doon Buggy
Started by Brookster, September 15, 2017, 09:26:08 AM
Brookster
Doon SWB
  1. Brookster
Good morning
Great Forum here's my project .
my plan was originally to by a Doon kit and build my buggy from scratch but 4 weeks ago i found the Doon Buggy for sale 3miles away for a great price.
Doon SWB built 2008
1971 Chassis
1641cc
Twin Weber 34ICT Carbs
Swing Axle
AB Gearbox
Had a few jobs to do straight away to get it running 100%
I have had the A frame  fitted so we can tow the buggy with or motorhome to France every year
i've also had fit all new engine mounts as the movement was making it jump out of 1st gear due to the excessive movement.
Future plans are to fit my 12A Rotary Engine
SWB Doon No 16
1641cc Twin Weber 34ICT
Looking forward to hearing more of the conversion - Nice Buggy  ;-)up
Nice buggy and engine conversion compact and smooth.
Oooh!  ;-)up
That's very interesting and I too look forward to seeing the rotary engine going in  ;-)up
It's nice to see Doon S016-08 has gone to a good home  :)
Quote from: Peter on September 16, 2017, 12:43:12 PM
Oooh!  ;-)up
Pete... Do you remember the RSU wankel rotary engine when it first appeared in the UK and the rotor seals lasting about 1500 miles maximum, (from new that is). ?
Brookster
Doon SWB
  1. Brookster
Quote from: Paul1953 on September 18, 2017, 11:10:22 AM
Oooh!  ;-)up
The Apex seals are alot better these days  ;-)up
i'll be running pre- mix too , all the oil injection system has been blanked off .
SWB Doon No 16
Pre mix in a buggy, will be hard to shake it up after it has stood unlike the 2 stroke moped you could man handle easily.
Brookster
Doon SWB
  1. Brookster
Quote from: snoopy on September 18, 2017, 12:21:14 PM
it will be ok i have 2 x 2 stroke bikes  ;-)up
it takes 3 weeks for the oil to seperate if not remixed , plus i have aload of speed bumps of or road to remix it  8)
better than injecting engine oil from the sump which isn't designed to be burnt, pre mix will extend the engine life .
no Rotary lovers on here then ?  :-\
SWB Doon No 16
I know we have a few rotary lovers on here
One in a silver Buggy, one in a black rail, and I think (PhiilpM?) may have had one in his rail previously?
Brookster
Doon SWB
  1. Brookster
Quote from: Dave DND on September 18, 2017, 04:25:22 PM
cheers  ;-)up
will have a look for their threads  8)
SWB Doon No 16
Never heard of 'Apex Seals' but hopefully they will do the job, Yes!, I do remember
the failures in the early days but things have developed over the years in leaps and
bounds and nothing stands still with technology these days  ;-)up
Quotei have 2 x 2 stroke bikes
Oooh, that's excellent, and what might they be then ?  :)
Didn`t say I wasn`t a rotary lover. There has to be many benefits. Much more compact than a piston engine. Fewer moving parts and I presume lighter. I worked with a guy who bought a NSU with the first generation rotary wankel engine. After only a couple of weeks it was returned to the dealers and a second engine fitted. Same thing. Both occasions rotor tip seals. became a National issue. I know the problem has been resolved but have never been up close to a modern version.
Brookster
Doon SWB
  1. Brookster
Kennedy Engineering adaptor kit has arrived as well as the stage 2 clutch kit  ;-)up
Just awaiting the arrival of the Weber 48 IDA now  ( Bridge Port Spec )  :)
SWB Doon No 16
Brookster
Doon SWB
  1. Brookster
#13
Rotary Buggy from South Africa
Australian Rotary Buggy & Beetle ( very popular conversion in OZ )
SWB Doon No 16
Brookster
Doon SWB
  1. Brookster
#14
The standard water pump has been removed as i will be running an electric water pump
as a result the alternator has been relocated with a Franklin Engineering kit from NZ
Uprated 8mm HT leads too fitting on the Lead and trailing spark plugs
12A Bridge Ported 240bhp spec with 48IDA Weber Carb spec
Weber 48 IDA Spec
SWB Doon No 16
