200mm SACHS 3 Piece Clutch Kit (No Pad) 311198141A
Started by Dave DND, August 24, 2016, 08:48:04 PM
Standard 3 piece clutch kit 311198141A
Clearing out the garage and just found this - Brand new in box and surplus to requirements,
as the chances of me going back to a Type 1 engine are now virtually zero
The kit is designed for use with a late gearbox with the guide sleeve over the input shaft - (Later No Pad / No Ring style)
Included in the kit is the release bearing with integral clips, 200mm friction plate and 200mm pressure plate.
Manufactured by Sachs (Best Quality)
VW Heritage list at £105 + Post
£75 + post (or can hump / dump)
Bloody heavy, and can stick it on a Parcelforce courier for a tenner if needed
Still got this if anyone interested  :-\
Hi Dave, I'll have it off you, I'm sure it will come in handy ;-)up If you can remember to bring it up when you come :D
Cheers Rob
Consider it yours Rob - Trying to get up next week if I can  ;-)up
