Flatlands steering support off centre
Started by Ioan Ford, November 20, 2026, 06:51:18 PM
Ioan Ford
Manx Meyer
Has anybody encountered a problem with the flatlands steering support  brace in relation to the steering wheel not been perfectly central to the driving position? Mine is adjusted as far as it can go to the off side ( right from driving position) yet it's still off centre and is too far to the left. I can't nudge the square section that's bolted firmly to the underside of the windscreen line as it's already butted up tight into the bonnet moulding. Any ideas or experience of this guys?
Am sure others on the forum will have had experiences......  One of the things I found with my Manx body tub, and it was freshly, "out of the mould, is that the tub is far from symmetrical or "square. It`s quite noticeable how much the shape alters between a hot summer and a freezing winter. That`s just how "fibreglass is". Mark, of Flatlands Engineering did tell me the steering support was designed for a Manx as a result of his first attempt at IVA being, in his words, a dismal failure. Remember it`s a buggy and a lot of things are "make do".  I am tied up today taking my young grand daughter xmas shopping. As soon as I can I will take a photo of the support and steering wheel position.  on my buggy.I can say now that the steering column/inner shaft is in a straight line axially right through to the steering box with zero distortion at the flexi coupling.
Ioan Ford
Manx Meyer
Thanks Paul. Makes perfect sense.  Might gave to finally make do with it being slightly out.  A pic of yours later would be great. Enjoy the xmas shopping!!
Right....  Just to jog my memory I took a lie on my back,  (really not easy anymore with legs stuck up over top of seat. Can fall in .. but getting back up and out  ;D  ;D ).
A photo initially to give you some idea how my steering column/wheel lies in relation to my seat. The photo is taken by a camera on the centre top of the drivers seat. Note the two red arrows. These just point out where I slitted rounded "U" shaped edging to satisfy the daft rounding needed just about everywhere. I was in the fortunate position of having a new body tub so I knew I had to get the steering box to steering wheel dead straight axially. I have seen so many attempts where a hole has been drilled in the tub and it`s not where it needs to be so more drilling/hacking is done. Many with plates etc stuck over to hide a massive irregular hole. So for anyone wanting to get the position of the hole just right first place the steering box on the beam where vw meant it to be. Leave the clamp bolts just a little nipped so that you can rotate the box.  Get a
length of 15 to 16mm i/d pipe and it will slip over the steering box shaft. Then using the other end of pipe as reference you can rotate the box to where the hole in the tub needs to be. That`s it you have a hole in the right place first time.
Next two images......   These show where my Flatlands steering support locates at the bulkhead. I cannot get a meaning full shot of the nearside to offside square tubing due to the dark and other things obscuring it.    Note the "A" & "B" letters on the images. "A" is on the stainless steel plate that shuts off the bulkhead from the fuel tank area 100%. This has to have the upper & side edges sealed. "B" is an additional plate that secures to a cut out in the main bulkhead plate so that I can get into the fuel tank filler stuff to ensure the filler tube clamps remain 100% secure and to access to the fuel gauge wiring. If you make a secondary plate like I have it has to be secured at all 4 corners and have a sealing gasket between it and the main plate.
Fuel tank..... Must have means to ground it to chassis. I have a threaded stud brazed to the tank so that I could run a ground w
ire to the chassis immediately below. It has to be in a position whereby the examiner can see it is grounded both ends.. He will check. Tank must be visibly vented. Tank must have a "roll over" shut off valve fitted.
Ioan Ford
Manx Meyer
My tank is grounded and I have a photo to show inspector.  No breather pipe but the fuel cap has a pressure release valve fitted so it vents from there. That'll suffice surely??? Roll over shut off valve?? How did you do yours as I dont currently have one. The list goes on!! Cheers Paul.
I think when i did mine i put longer bolts in and packed one side with washers to shift it over to correctly centre it
I know the manual states photos of things out of sight. But, and this was just my examiner of course,  was not happy with photographs. This reminds me of something..
Seat belts....  3 point retracting are preferred. The seat belt mounting points along with seat fixings themselves require "plates" that are 4mm thick minimum x 100 x 100 minimum. I cut out and moved the original tunnel mounts. If you have a look they are "double thickness" plates so spot on for IVA. I ground down the outer welds flush to the tunnel so they look as though  they were as from factory. Deliberately left the inner weld proud of surface for strength. Took photos but he wasn`t happy so off with the tunnel cover and a boroscope down to check welding was 100% around all four edges of the rectangle. Seat belt securing bolts are specific to seat belt fixing and are marked with a squiggle. Have a photo somewhere. Fuel tank pressure release.... Not sure about that. The vent pipe`s purpose is to keep the tank inside at atmospheric pressure and ensure no vacuum can be created, (This was an issue back in the 50/60 & 70`s.).    Rollover valve. Steer clear of ebay rubbish, I talk from experience here, go for one that is decent. From car builder solutions etc. Sadly a decent one is not cheap...  Back to fuel tank. Working fuel gauge needed. Vent pipe is needed. The rollover valve needs tank connection with a pipe to atmosphere and the valve correctly orientated. If you still have access to tank then you can get a version that fits to a suitable sized hole. (Picture to follow). Now remember I am describing my experience.... here is an example of how one examiner can differ to the other so nothing is "cast in stone". Flatlands Mark and I discussed buggy building and IVA at length at his premises. I was grateful for all the advice. One of the things he said was needed at the Norfolk vosa station was a tap fitted to the tank so that the examiner could check the accuracy of the fuel gauge at empty, 1/4, 1/2 & full. (You are asked to arrive with a full tank but in my case that was just for weights etc). The tap is still present wired closed but has never been used). I keep getting comments of "why go to such bother... it`s ridiculous... just put a buggy on the road.  The answer to this is dead simple. I was told before I started iva was impossible with full windscreen, roll hoop and demisting. I set out to prove that statement wrong  I never saw the point of putting things on just for iva and taking off afterwards and believe me if people had not put such things on social media , forums etc things would be far more lax than the are now. When I meet people, that like me are true petrol heads,  hours are spent talking/showing what I have done.
 Technically DVSA can revoke an IVA pass if the vehicle is then modified to suit the owners original want for the car to suit the period or design that would fail IVA. Have seen plenty modified after but not heard of any pass certificates being voided and registration removed.
Quote from: snoopy on November 23, 2026, 08:48:51 PMTechnically DVSA can revoke an IVA pass if the vehicle is then modified to suit the owners original want for the car to suit the period or design that would fail IVA. Have seen plenty modified after but not heard of any pass certificates being voided and registration removed.
I always assumed that any modifications on an IVA'd car were classed the same as on any other vehicle, ie the IVA test is just a type approval test for a unique vehicle just like any mass produced car is type approved.
Surely as long as any mods follow the legal guidelines (8 point rules as were or the modern equivalent) then all would be good.
I have not looked but there was a thing on it when iva came about that the certificate should stay with the vehicle when sold so compliance specification could be checked at anytime and pass withdrawn if deemed necessary with changes.
We are lucky in the UK you go around Europe and in some countries you do see any modified cars on the roads others have a few but nowhere near our numbers although the MOT is supposed to be tightening up on the emissions side for decats, egr delete and chipping being a failure.
I doubt if any government agency would have the manpower to police any possible mods on IVA'd cars anyway... I so much doubt they'd really be bothered. I've heard rumours of modifications having been flagged up on cars but never seen or heard of any actual proof.
The basics regarding changes post IVA approval according to the examiner is that minor changes are allowed providing that the change/s align with the "requirement". An example would be that the item had correct curved edging and so on.
The IVA Certificate is strictly controlled. The original goes to DVSA with your application for 1st registration. All submitted documents are returned with the exception of the certificate. DVSA keeps the original for obvious reasons. Upon sale of the vehicle the new owner can be certain of a genuine pass because the examination results in you being provided with quite comprehensive print outs of the original test data..  all measurements with a indented pass on each category. The original photograph taken by the examiner is available to view (This database is accesable to the boys in blue).. When you leave and are handed the certificate you are told "not to lose it before submitting  it to DVSA".  There is no means of getting a second one... it`s through the whole thing again. Doubt very much anyone has lost one
