blue metalflake 66 prowler
Started by Big Clem, February 22, 2013, 10:31:56 PM
Krug
Just looked at your pics... one shows a cage ?  Do you have one fitted???
Big Clem
66 prowler
Quote from: Krug on March 04, 2013, 04:33:50 PM
Hi krung its yourfault as I do have a tendency to ocd ;D andsaw your exhaust  ;-)up  the cage and bars that were on it are ok but a bit heath Robinson  ::) so having them made in shiney stuff  ;-)up rear cage im having made is  a simlar  to manxter style and hope not to hide exhaust ? ! Hope to have them by end of month
Big Clem
66 prowler
Quote from: Bajabug on March 04, 2013, 02:11:48 PM
Hi Clem whats your set up on the front to get it that low.
adjustable front beam that was on it welded in low so dose not raise much and ball joints at to much angle? So might raise it and put some drop spindles on to take out the ball joint angles ?
Quote from: Big Clem on March 04, 2013, 07:34:48 PM
a good idea it will handle better with the dropped spindles but you can get long travel ball joints.
Big Clem
66 prowler
Quote from: snoopy on March 04, 2013, 07:37:46 PM
ive seen the ball joints but figured would be better to go drop spindle route ??
Big Clem
66 prowler
sun was out briefley today so washed my van (black van and ocd not good  ;D )then pushed the buggy out to time it up with timing light not done this on a motor for about 20 years :o  was bang on from static setting when installing new dizzy just went over every thing cheeking for lose nuts ect gear box front mount needed thightening as is a crap red polly job so will order a rino one as this seems to go loose often ? still waiting on stainless bars to be finished but with this weather im in no rush  ;-)up but i want to get out in my buggy  :'(
chris bulls head
Hot rod ...buggy !
Baz
That's a gorgeous buggy Big Clem :)
Big Clem
66 prowler
well got my stainless bits done martin has done a top job not had any time to work on it so will get it all back together at week end and hopefully get my fist drive of the year :) ;-)up tried som thing a bit diffrent with rear cage so not to hide mikes top work
parmaynu
Nuffin
That's shiney!!!
Old Skool Parts Shop
oldskoolpartsshop.com
grissley
very nice stainless work and exhaust but I can,t do with the massive overhang they create. each to there own .  ;)
chris bulls head
Hot rod ...buggy !
clem looks the nuts dude top job ;-)up
volksferkin
jas lwb
Very nice you'll have fun keeping that clean , just out of interest what size are the back tyres
Krug
Keeping it clean... with OCD thats the point... it is fun to keep it clean  ;D ;D ;D ;D
Looking good.....
Just from experience and hard to tell due to the angles of the pics... is the end of the exhaust pointing slightly up?  If it is (and my one did at first) I was stunned how good they are at collecting rain and condensation.   Kicked all sorts of wet crap out untill I turned it slightly down and its much better now.
BEELZEDUB
Vulture???????
I did notice the tailpipe pointing up, it was built to point down slightly
