Scat oil pump filter full flow
Started by grissley, July 03, 2018, 07:28:06 PM
grissley
Will the scat oil oil pump filter fit on the engine with a rear cage fitted or does it foul the cage
HUDGE BUGGY
GP Mk2 Super Buggy LWB
Is it similar to this set up ???- if so no.
grissley
That looks bulkier than just a filtr
HUDGE BUGGY
Well a oil filter tin case  is about as thick as a fag paper,  the cover does just what is supposed to do, protect it from damage.
And being bulky has nothing to do with your question. ;)
grissley
#4
Coarse it does , if you. Cover the filter its obviously bulkier .
Where will it foul the cage as mine looks as if its above the bar just ! :-)
Isn,t that the cage tube below the filter in you picture ?
paul
ctr
Mine just fits behind the cage , though i don't have a cover on it.
grissley
Thanks paul for your picture, I knew it was tight but now I can fit one
Cheers all
