Front Lefthand (Nearside) axle hub nut.
Started by Hunter, June 17, 2018, 04:49:22 PM
Hunter
SDBC Moderator
CTR
Hi Guys,
As it says in the title,
I'm in need of a nearside front axle hub nut, thats the one that is lefthand threaded.
Cheers H
Is that for a king-pin beam (two nuts that you lock together) or ball joint beam (single nut with the allen bolt clamp)
Hunter
SDBC Moderator
CTR
Hi Rob,
Its for the balljoint version with the locking allen bolt!
H
I should have one somewhere, I'll have a look tomorrow ;-)up
Hunter
SDBC Moderator
CTR
Quote from: farmer rob on June 17, 2018, 09:05:02 PM
Hi Rob  8) ,
Holdup, Thanks for the offer.
Turned the bloomin garage upside down and by sheer luck found one in amongst some of the buried stuff and its the right one  ;-)up.
Cheers Hunter
Quote from: Hunter on June 17, 2018, 09:36:53 PM
Hi Rob  8) ,
Cheers Hunter
but you asked for a left one!  ;D ;D ;D ;D ;D at least you are now sorted
Hunter
SDBC Moderator
CTR
Quote from: snoopy on June 17, 2018, 10:21:35 PM
Hi Rob  8) ,
Turned the bloomin garage upside down and by sheer luck found one in amongst some of the buried stuff and its the right correct one  ;-)up.
Cheers Hunter
Thanks Snoops  ;D  ;D
H
Lefty loosely, righty tightly. Unless it's a left hand thread  ;D
Paul
