Started by Dave DND, May 02, 2017, 11:37:45 PM
baloo
Hi Dave
  did this engine go into something and all work ok ?
ive got a 2lt manual forester on an R reg do you think its likely that your wiring chart will work  if i pull the engine and put it in a buggy ?
or would it make more sense to lift the whole loom out as use it complete
Project is on the back burner still, but I do intend to finish it one day - engine is running on my test rig but never got as far as the Buggy.
Loads of ECU variations, so check numbers on your ecu and wires in locations on my chart to be sure, but if you have the chance of pulling the loom and anything connected to it, I would advise to do so (key barrel and immobilisers) and that way you can always hand the loom over to someone for conversion if unable to do it yourself.
baloo
i will strip it over xmas and do as you say and remove the whole loom ign etc
thanks Andy
