Hi all, just getting the column wires from the indicator switch sorted , the green light for the indicators in the bottom centre of the speedo , anyone know which wire/s I need to connect to this ? I have L and R indicator wires and a wire from the flasher can but my flasher relay is in the Cbs module / fuse box do I need the flasher can wire that is in the bunch of wires exiting the column? Thanks
Guessing the cbs relay has 3 pins held so you are looking at two vertical and a horizontal one at the top, top pin is warning light, l/h pin is live the right pin is to the switch and indicators.
The beetle used a 4 or 5 pin relay. On the switch from memory black with green and white tracer is feed in and black/white and black/green go to the lights.
Thanks again snoopy and all
