Trading Zone => VW Parts For Sale => Topic started by: PhillipM on July 27, 2015, 11:45:38 AM
Title: Wide-5 steel wheels - 6J and 7J wide (NOT banded!)
Post by: PhillipM on July 27, 2015, 11:45:38 AM
As above, selling our old steelies now we've switched to alloys, these were custom made with laser cut centres and spun barrels - they aren't cut and banded like some, and they come with part-worn Fedima EvoExtreme tyres.
The rears are 16x7J and have 235/70R16's mounted on them, approx 7mm of tread on one pair, and 10mm on the other pair:
(http://img.photobucket.com/albums/v89/Rippthrough/buggy201213/sides2k.jpg)
(http://img.photobucket.com/albums/v89/Rippthrough/20130508_200605.jpg)
I also have a pair (there might be 3 actually, will check) of fronts, which are 16x6J, with 195/70R16's on them:
(http://img.photobucket.com/albums/v89/Rippthrough/NewFrontBonnet.jpg)
Bear in mind these are raced items, with a year or two of offroading, so they have dents, dings and will probably want straightening out and repainting - unless they're going on a Baja/Rail, in which case bolt on and have fun  ;D
I'd take £350 for the lot to get them out of the way (the Fedima's are £110 a piece new now alone!), I might split the wheels and tyres if requested. Possibly split into a set of just 4 wheels too.
As we've also changed the front hubs to fit new alloys, I'm selling the wilwood 5-star front hubs, so there's a pair of brand new brake discs and the 2-pot forged dynalites (great condition, only been on a year) up for grabs if anyone makes me a sensible offer:
(http://img.photobucket.com/albums/v89/Rippthrough/moto_0178.jpg)
These are the calipers if the photo isn't clear:
(http://www.motorsport-tools.com/wilwood-dynapro-2-pot-rear-brake-caliper-lug-mount.html)
And the discs (part worn set on the hubs, although very little wear - but there's a brand new pair to go with the calipers too)
(http://img.photobucket.com/albums/v89/Rippthrough/BuggyDiscsFront.jpg)
Disc dimensions:
- 10" diameter, with a 1.5" swept surface for the pad, 8 bolt holes on a 5" PCD (bolt holes are countersunk for M6 fixings), internal diameter is 110mm and they're roughly 7mm thick.
Title: Re: Wide-5 steel wheels - 6J and 7J wide (NOT banded!)
Post by: PhillipM on July 27, 2015, 12:50:39 PM
^^Just in case that wasn't clear there's 4 of the 16x7J's, and 2 (or 3 if I can find the spare one) of the 16x6J's
Post by: PhillipM on July 31, 2015, 10:40:31 AM
Right, found the spare front wheel, although not the tyre yet  ;D
Anyway, to make it easy, £110 per pair for the wheels and tyres, and the same for the calipers and new pair of brake discs - £110 takes 'em - if someone wants the odd wheel PM me and we'll sort something :D
