Trading Zone => Parts Wanted => Topic started by: Dave DND on June 23, 2015, 11:17:56 PM
Title: Wanted: 4x130 to Chevy 5 stud wheel adaptors
Post by: Dave DND on June 23, 2015, 11:17:56 PM
Be wary of others working on your car    >:(
Need a pair of 4x130 to chevy 5 stud wheel adaptors
Title: Re: Wanted: 4x130 to Chevy 5 stud wheel adaptors
Post by: Manxdavid on June 24, 2015, 06:59:08 AM
What's happened? Can't any damage be repaired?
Post by: Dave DND on June 24, 2015, 08:09:27 AM
After being attacked by an Ape with a ratchet gun on full tilt, lets just say the threads are a little "stressed" and for peace of mind I am going to change them
Post by: Manxdavid on June 24, 2015, 09:09:54 AM
Can't you just knock the studs out and replace? Speedshack or Mr Tee should have something. 7/16" unf.
Post by: Dave DND on June 24, 2015, 09:17:12 AM
Hmm . . .
Not considered that one - will pull one off later and see how easy that is to do   ;-)up
Post by: Manxdavid on June 24, 2015, 09:26:00 AM
They just knock out, and any replacement ones that you get are bound to be better quality than the OEM ones. The only problem would be if the dog-leg studs are damaged as they're made of unobtainium. I may have one or two if you're stuck though ;-)up
Speedshack will do studs in that thread for old MkI Mexicos/RS2000s etc. Not sure about the dimensions of the knurled parts though.
http://www.speedshack.co.uk/Wheelnuts.htm
Post by: Dave DND on June 24, 2015, 09:32:40 AM
Quote from: Manxdavid on June 24, 2015, 09:26:00 AM
Whats a Dog leg stud ?   ???
Post by: BuggySteve on June 24, 2015, 09:45:57 AM
Quote from: Dave DND on June 23, 2015, 11:17:56 PM
Think I have a pair Dave. I'll have a look this afternoon after work
Post by: Manxdavid on June 24, 2015, 01:37:13 PM
Quote from: Dave DND on June 24, 2015, 09:32:40 AM
https://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-6778
Post by: Dave DND on June 24, 2015, 02:11:30 PM
Quote from: Manxdavid on June 24, 2015, 01:37:13 PM
Understood   ;-)up
Steve, if you do come across any - give me a yell   ;-)up
Post by: BuggySteve on June 24, 2015, 03:56:04 PM
I have a pair of said adapters machine 7 supplied Empi make billet aluminium inc dog leg studs. They were test fitted then removed so as new.
£40 plus post so £45?
Post by: Dave DND on June 24, 2015, 05:56:09 PM
PM sent Steve   ;-)up
Post by: Dave DND on June 29, 2015, 05:32:31 PM
Cheers Steve
Arrived safely   ;-)up
