Beach Buggy Help Zone => Beach Buggy Body and Chassis Help => Topic started by: ben79 on December 03, 2014, 06:55:04 PM
Title: fuel caps
Post by: ben79 on December 03, 2014, 06:55:04 PM
Im buying bits for my build and looking at the fuel fillers on some of your buggy's I quite like the monza style flip up type, wheres the best place to get a fair quality one and what size is best? 2" or 2 1/2" and also what type of neck would I need?
Cheers guys ;-)up
Title: Re: fuel caps
Post by: snoopy on December 03, 2014, 07:28:18 PM
2" filler tube will fit into the beetle filler hose a 2.5" will need a reducer or a larger tank connection tube. there are a few ways of fitting fuel fillers it also depends where it is sited.
a vented cap is a good idea if it is mounted on the bonnet and then there is no need for a breather vent tube but it may leak if side mounted with fuel surge on cornering so a sealed cap with breather tube would be better.
Post by: apmaman on December 03, 2014, 07:51:56 PM
Are you using the original tank or a repro?
My repro tank (1962+) has a smaller neck ID than the originals, and such needs a different fuel cap, which can come separately. It does not lock as well which is a bit annoying.
Post by: HUDGE BUGGY on December 03, 2014, 07:55:47 PM
I've had a quick scan thru the forum and can't find the topic
But wasn't someone on here selling these in ally and stainless  ??????   might save yourself a few quid ;-)up
Post by: HUDGE BUGGY on December 03, 2014, 08:02:24 PM
 FOUND IT
Quote from: anoldgit on October 23, 2013, 07:10:25 PM
Hi all new here so go easy with me
Large billet alloy fuel cap lids
Details/pics in a short while YIPPEE it works!
all Sales Manufacturing All Sales Direct Fit Fuel Door - JCWhitney
Large NEW billet alloy fuel cap lids+billet alloy carbon type
16cm outer ring diameter made from solid 6061-T6 aircraft grade aluminium
Absolute STUNNING quality
Post by: ben79 on December 03, 2014, 08:44:08 PM
Many thanks for the replies, I wanted the filler to be central on the bonnet, so if I get the vented cap it wont need any breathers? Cheers hudge but I think they are the flush fit ones, im after the monza style, looked on ebay and unsure if they are the same as flatlands ones
Post by: Manxdavid on December 04, 2014, 02:04:25 PM
In the past I've used a commonly available Aston type cap made for classic Minis fitted to an MG Midget type filler neck and rubber gaiter. It flips open to access locking cap (also Mini) and is vented.
(http://images.thesamba.com/vw/gallery/pix/314173.jpg)
(http://images.thesamba.com/vw/gallery/pix/314174.jpg)
All bought off eBay... same as this... http://www.ebay.co.uk/itm/Chrome-aston-petrol-cap-and-stainless-locking-petrol-cap-Classic-Mini-/361137813581?pt=LH_DefaultDomain_3&hash=item54157db84d
Post by: snoopy on December 04, 2014, 03:58:59 PM
Thats a neat idea to get a lockable cap with a flip top
Post by: AndyRobinson on December 04, 2014, 04:12:19 PM
Actually very nice indeed.
I went for a beautiful crafted one with a screw top and locking vented cap within it. Absolutely go for vented if you can. Some other bits I would advise. It looks like the one David mentioned above allows you to take the bonnet off without having to unbolt the clamp on the tank itself - trust me this is a great idea (Mine you can't and so have to climb underneath to get to it - not easy) OK its not often you take the bonnet off but it will make life much easier when you do.
Also if you get a tank from flatlands for example, make sure the filler cap "tube/neck" fits down and well within the neck on the tank which will have a small slit in it to aid clamping together. My custom one wasn't and so left a small gap meaning fuel could spill out if full and going around corners. (Still it helped venting too! ;) )
Post by: buggysam on December 06, 2014, 06:39:25 PM
Mr R, Where did you get yours from? Id like a retro one that fits but can be removed to make gettin the bonnet off easier, If its not to expensive then may explore the options.
Post by: AndyRobinson on December 06, 2014, 08:08:08 PM
From here....
http://brasscraft.co.uk/index.php/fuel-caps.html
The chap is found at  Stoneleigh, as you can see he produces a load of very fine stuff for Cobras and the like. Hunter knows him too. It's a beautiful piece of work and cost me.... Including VAT and shipping £200. So think carefully! It's made up of the 2x images from the right on the top row.
I do like it, it's different, if I was building another buggy (with unlimited funds) would I choose it again? Probably not. The neck to the tank needs to be longer and yes you still need to clamp it down below the bonnet so access is tricky when removing the bonnet.
Post by: ben79 on December 08, 2014, 04:21:37 PM
Thankyou for the info, ive now ordered the one david has put up, looks a good price and exactly what im after. Cheers guys ;-)up
Post by: Manxdavid on December 08, 2014, 04:33:23 PM
You'll need the tank/filler neck off an old Mini, Midget, MGB, FX4 Taxi or similar age BL/BMC car to fit it to.
Post by: kustom kriss on December 15, 2014, 10:01:32 PM
I used a similar cap but frenched it flush
(http://i671.photobucket.com/albums/vv79/klumberkriss/cars/IMG_20141110_190526_2_zpsnnyv9gsw.jpg) (http://s671.photobucket.com/user/klumberkriss/media/cars/IMG_20141110_190526_2_zpsnnyv9gsw.jpg.html)
