Trading Zone => VW Parts For Sale => Topic started by: crowncorvair on August 22, 2014, 01:37:20 PM
Title: Disc brakes for a beetle
Post by: crowncorvair on August 22, 2014, 01:37:20 PM
Hi The brakes on my Thomas crown Replica are vented discs - The original car had drums.
The Disc  brakes have done about 10 miles -
Does anyone want to swop a set of Front Drums with Chevy pat studs for a set of Front vented discs/(http://i36.photobucket.com/albums/e26/crowncorvair/IMAG0448_zps01913603.jpg) (http://s36.photobucket.com/user/crowncorvair/media/IMAG0448_zps01913603.jpg.html)
If anyone is interested can send more pics
Martin
Title: Re: Disc brakes for a beetle
Post by: Jazzy Early on August 22, 2014, 02:45:23 PM
is chevy pattern 5x120.65....??
Post by: crowncorvair on August 28, 2014, 01:41:54 PM
Hi PCD is jag Chevy - which I believe is 4.75 inched  pcd
(http://i36.photobucket.com/albums/e26/crowncorvair/DSCN0317_zpse5b23015.jpg) (http://s36.photobucket.com/user/crowncorvair/media/DSCN0317_zpse5b23015.jpg.html)
(http://i36.photobucket.com/albums/e26/crowncorvair/DSCN0314_zpsbf133f88.jpg) (http://s36.photobucket.com/user/crowncorvair/media/DSCN0314_zpsbf133f88.jpg.html)
All I need is a set of drums and studs to swop
Martin
Post by: muzzy01 on August 28, 2014, 02:01:08 PM
i might if you can wate till winter
Post by: Flags on August 28, 2014, 02:02:24 PM
I've got to ask why?
Drums with a corvair engine will be a serious backwards step.
The original car probably had a single circuit master too but you wouldn't want to go there
Post by: AndyRobinson on August 28, 2014, 02:33:41 PM
With Flags here... OK you want it authentic but going by the photos you have done a truly amazing job. But for a part thats not seen and is crucial with such a corvair engine, I would stick with the discs. After all you are going to be driving it an awful lot more than just on the beach for a few mins chasing the seagulls with Faye Dunnaway.  ;-)up
Post by: Jazzy Early on August 28, 2014, 09:45:35 PM
I will have to do an imperial measurement.
I am sure my Pcd is Chevy, as mentioned above...
Post by: Flags on August 28, 2014, 10:37:23 PM
If it's just about the look then how about fitting back plates and having a fibreglass mould made of the front face of a drum, stick those behind the wheel and you would be hard pushed to see the discs.
Like these but in reverse.
http://www.ebay.co.uk/itm/Silver-high-quality-Universal-Aluminum-Disc-Brake-Racing-Cover-Drum-latest-new-/121101297832?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c323328a8
Any car tuner worth his beans will tell you to go fast the first thing you have to upgrade is the brakes.
Post by: Manxdavid on August 29, 2014, 12:51:10 PM
TBH you'll struggle to find any stud patterns other than the stock 'wide 5' when it comes to king & linkpin type front drums.
I've never seen any different stud patterns available 'off the shelf' and the standard design stops them from being re-drilled, hence the almost universal use of cast ally wheel adapters 'back in the day' in the US.
Sorry if this peees on your chips... :-\
Post by: Jazzy Early on August 29, 2014, 04:01:01 PM
my wide 5 drums have adapters on them to fit my wolf race wheels, which I am sure (not positive) are chevy pattern.
You are welcome to give them a spin (excuse the Pun) if you want to....!!
Post by: Manxdavid on August 29, 2014, 05:48:27 PM
Quote from: Jazzy Early on August 29, 2014, 04:01:01 PM
Is your front end not a ball joint one? It should be if it's  67.
Post by: ben_w on August 29, 2014, 07:54:57 PM
To be honest Martin, I have to agree.
Unless you are going for an absolute concourse class replica, leave them be and spend some money on the rears. I've found several times that I've had the extra weight (and hence inertia) pushing me on when trying to stop. I've got discs up front but the low tyre pressure and distinct lack of weight over the front (despite the driver, before one of you f...ers gets in there!) finds me locking up quite easily and the extra weight just pushing.....
When I can afford some blank type 3 hubs ($300!!!) I'll be converting to type 3 on the rear......if your discs would fit my wheels, I'd have had them. Unfortunately, I'm a 5" pcd Chevy fit, not 4.75 and I could do without the hastle of drilling and studding again....
Post by: Jazzy Early on August 31, 2014, 08:19:15 PM
Quote from: Manxdavid on August 29, 2014, 05:48:27 PM
Yessum, I am on ball joint... Is the other on king ?
Post by: crowncorvair on September 01, 2014, 06:37:35 PM
Hi the Suspension is link pins - It is the one part that is not correct  - but I will change it to IRS this winter - If anyone knows what rear arm assemblies I should look out for that would be great - also if anyone on the south coast can do it for me that would also be good
Took it out again this week end - it is a bit of an animal!!
Martin
