Beach Buggy Help Zone => Beach Buggy Engine and Exhaust Help => Topic started by: apmaman on May 22, 2014, 02:43:21 PM
Title: very loud banging noise left hand side of engine
Post by: apmaman on May 22, 2014, 02:43:21 PM
Started up the car today and there was a very loud banging noise coming from left hand of engine. Turned the car off straight away...
Ive took exhausts off and had a wee look inside the exhaust ports nothing seems loose etc. Checked the valves and theyre all fine none loose.... dont really want to start it up again encase its something very serious.
Any ideas? :(
Title: Re: very loud banging noise left hand side of engine
Post by: apmaman on May 22, 2014, 02:55:34 PM
Tried rotating by hand and will rotate so far then refuse to go forward or backwards now... looks like somethings came loose in cylinder???
Guhh sh..e! Totally loosing the will to live with this thing!
Post by: child of the 70s on May 22, 2014, 03:36:22 PM
i had that in mine when i first started it.
turned out it was a washer from the brand new carb hadnt been fitted, much have been floating loose.
anyway it got sucked down and mangled itself into my new piston.
i now have that knackered piston on my desk to remind me not to trust new suff.
take your heads off and have a peak.
but do it with a smile...
Post by: apmaman on May 22, 2014, 03:57:30 PM
Blahhhh I'll read up how to do it next week, really not in the mood!  :-X Just when it was about to phone to arrange a rolling road setup... Is it a difficult job? IE engine out etc as ive never done anything that big of a job before.
Only thing I can think of is if ive accidentally knocked in a washer when re-assembling the carbs  :( :-\
Post by: snoopy on May 22, 2014, 04:36:38 PM
Have you had the plugs out I have seen the centres come loose and fail making noise.
Take the belt off and spin the dynamo incase the fan has thrown a piece off.
Post by: apmaman on May 22, 2014, 04:57:08 PM
Not tried the plugs ill give them a check.. fan looks fine as its a type 3 motor its pretty easy to see inside the ducting...
Could have been a plug has self destructed I guess..  Urgh Just everything always happens to me.... Hope I win that grand in your hand off the radio competition tonight!!!  ;-)up :D ;D
Post by: Shaggy on May 22, 2014, 05:02:58 PM
Take out your plugs and using one of them cheap extender magnets(looks like an old car aerial) have a fish round in each cylinder to see if you find any debri, this may at least point you to which side to strip down or even clear the item causing it to be noisy.
Post by: GBHgpJON on May 23, 2014, 11:18:51 AM
Banging or ****ing loud rattle??
This is the remains of something.............it caused a lot of noise, but not exactly 'banging'.........the 'bits' where embedding into the head.
Drove about a mile like it............took head off, cleaned it all up, refitted head back, no ill effects ;-)up
Altho, when it 'went off' I thought it was all over!!!  :o
(http://i18.photobucket.com/albums/b128/gbhgpjon/2013-07-28163315_zpsa8abbeba.jpg) (http://s18.photobucket.com/user/gbhgpjon/media/2013-07-28163315_zpsa8abbeba.jpg.html)
Post by: volksrod brian on May 23, 2014, 12:55:26 PM
Quote from: GBHgpJON on May 23, 2014, 11:18:51 AM
How lucky was it that you put it back together all ok  ;-)up
Post by: GBHgpJON on May 23, 2014, 01:08:31 PM
Shows how bullet proof these engines are, we tend to be a bit precious about them IMHO..............funny thing was the head next door had similar damage from a previous event......
Usual suspect is often the soft metal plug on the side of the stock carb.......amazes me how these bits get past the valves on the way.....I've even heard of carb bits even spat from exhausts.
Post by: apmaman on May 23, 2014, 05:02:22 PM
It was a banging noise, it was a really loud harsh bang every time the engine rotated around full.
Well plugs out and they were all fine, checked the valves again just to be sure nothing was suck between them so looks like its something inside the cylinders...
Couldn't get a small enough magnet tool ma-bobber so had a look with a torch, couldnt see much. Off to phone a vw specialist on monday and see if they can take it on, hopefully there not just a diagnostics specialist! hahaha.
Post by: Shaggy on May 23, 2014, 06:13:34 PM
Had a similar thing happen to my old beetle. Stripped it, cleared out the debris and rebuilt it, ran fine for 5 years then sold it.
Post by: apmaman on May 25, 2014, 09:07:52 PM
If the piston & barrel are goosed, are they available as singles for replacement? Been trying to roughly price the worst case and seems like they all come in 4's.
If only 4's might as well upgrade to a 1641 ;)
Post by: snoopy on May 25, 2014, 10:06:28 PM
There will be plenty of used barrels n pistons about but there are dished and flat top versions. Got some dished ones here 1600 with barrels.
Post by: apmaman on May 25, 2014, 10:10:29 PM
any reason why the dished are better? I was looking at forged ones from vwhertiage £250 for 4 which seems ok.
Hopefully it wont come to this but im just checking rough prices.
Post by: Manxdavid on May 26, 2014, 03:15:27 PM
Quote from: apmaman on May 25, 2014, 10:10:29 PMany reason why the dished are better?
Dished pistons were for low compresion engines, generally Type 2s so they could run on crappy 2** petrol.
What cc's your engine at the moment?
Post by: apmaman on May 26, 2014, 03:19:19 PM
far as i know its a standard type 3, so 1584cc
Post by: snoopy on May 26, 2014, 04:59:10 PM
They do flat and dished top pistons for high and low compression as David says. A new quality set is fit and forget.
Post by: apmaman on May 30, 2014, 11:28:33 AM
Well worst case scenario it'll be about £250 for a set of 4 new pistons and barrels. These being some forged ones, not the cheapest of the cheap as I want it to last.
Hopefully no valves etc have been bent or crushed to add to the total..When I was on the phone to the mechanic first thing he said was "ho hoo, gonna be expensive!" Wonder what his rates are haha. Oh well... I guess its something that has to be done. No real escape from it unless I want a very large yellow ornament in the garage.
:'(  :'( haha! He was also adamant that I make sure all the tin wares on etc, I have it all but nothing on the bottom of the cylinders, as it was "committing motoring suicide without them"
Going down monday, so best bring me cheque book!
Post by: Zebethyal on June 10, 2014, 09:26:37 AM
Quote from: Manxdavid on May 26, 2014, 03:15:27 PM
Just about every aircooled VW engine is capable of running on 2* fuel, it is simply a matter of adjusting the timing, they were designed to run on the worst fuel available in Nazi Germany. The original Type 1 engine design specification was to be capable of transporting 2 adults and 3 children at 62mph, whilst using averaging no less than 39mpg. I am however not disagreeing with the low compression part. All of the aircooled engines that followed were simply variations on a theme that slowly produced greater levels of horsepower largely through increases in engine displacement.
Low compression engines may be more preferable for use as generators as low compression leads to longer life, lower heat output, lower cost of construction and greater reliability, at the cost of performance and efficiency. A higher compression engine  with the same parts will also have a tendency towards pre-ignition/engine 'knock"/"pinging" due to an undesirable burn pattern caused by excessive heat, this is often counteracted to a degree (pun intended) by changing the timing.
