Beach Buggy Help Zone => Beach Buggy Body and Chassis Help => Topic started by: CHARLIE-DONT-SURF on May 17, 2026, 08:57:10 PM
Title: Dashboard suggestions please
Post by: CHARLIE-DONT-SURF on May 17, 2026, 08:57:10 PM
So my dash isn't for me. I like standard ish looking speedo etc. I want to ditch what is currently in there (including the tacho under the dash and speedo on tunnel).
 Unfortunately my dash is only 10.5 cm (ish) high so no chance of fitting a standard speedo.
 Any ideas/suggestions as to the way forward? Ideally a 80mm GPS with all the  warning lights on would be ace but closest I can find is the Acewell one but that doesn't have oil/charging lights. So then I'd have to find something tasteful that looked period ish and not to garish.
 I might put the hazard warning and light switches on the dash also (currently they are modern switches hidden underneath). Pic is of current set up.
 Flummoxed tbh. Any ideas gratefully received. As I say, like the older more classic look.
 Fanks  ;-)(-;
(https://i.postimg.cc/9fcvCy6w/IMG-5192.jpg) (https://postimg.cc/9DNxBwFc)
Title: Re: Dashboard suggestions please
Post by: buggypete on May 19, 2026, 07:00:13 PM
A favourite 80 mm used to be out of rwd skodas,but most vdo bolt straight in ,and use VW drive,buggys don't need tachos if you can't hear a buggy exhaust you must be deaf,
Post by: Manxdavid on May 20, 2026, 12:07:06 PM
Quote from: buggypete on May 19, 2026, 07:00:13 PMA favourite 80 mm used to be out of rwd skodas,but most vdo bolt straight in ,and use VW drive,buggys don't need tachos if you can't hear a buggy exhaust you must be deaf,
Been there, done that, redid my old GP dashboard to fit matching Skoda speedo and tach from a Rapide, they looked beautiful and the speedo cable fitted straight away.
The problem was the speedo only read at half speed; great for limited mileage insurance, not so good for speed cameras... ;D  ;D  ;D
