I've had a we accident and damaged the end of the filler neck that the cap would sit on. ::)
Does anyone know where i can get a neck that the vw cap fits onto?
I'm at the stage of fitting it to the centre of the tank, so a one piece neck would be ideal
Centre bonnet fill you could weld a short pipe to the tank then fit an aero filler with a 50mm pipe andconnect them with a short hose and clips.
(https://i.postimg.cc/MKzHQrp3/IMG-1955.jpg) (https://postimg.cc/HjPTGz5b)
Thanks snoopy. That would also be an option.
I've already got a monza cap that fits round the vw neck and the vw cap fits inside the monza cap.
I know it's my own fault, but it will be annoying if I was hoping to go for this look.
I thought someone must sell the neck, but I can't seem to find it.
It was if course the cap fitting part I damaged
Somebody willhave a scrap tank to cut a good neck off as the bottoms rust out not the fillers.
That would be ideal ;-)up
You'll need the early type tank with long neck to bottom right corner as the newer ones only have a 2 inch neck.
Thanks chris.
I've posted in the wanted section.
Fingers crossed someone has one they are willing to sell
