Beach Buggy Help Zone => Beach Buggy General Help => Topic started by: mancityjeff on May 01, 2021, 05:34:34 PM
Title: carb
Post by: mancityjeff on May 01, 2021, 05:34:34 PM
Hi All
I have upgraded my bug from 1300 to 1600 twin port my problem is I had the engine all chromed and the issue is the throttle cable comes throuh at an angle from the fan shroud, i have a twin choke webber fitted and the cable is under strain to the carb and does not give free movement, is there an attacment that can be added to the throttle arm that drops down so to give a stright pull movemnet and not under tension, if anyone has had an issue like this could you post a photo how to get over this.
regards
mancityjeff
Title: Re: carb
Post by: snoopy on May 01, 2021, 06:25:27 PM
You can drill another hole in the fan housing to suit.
Title: Re: carb
Post by: Merscury on May 01, 2021, 07:44:15 PM
I cut I triangular piece of steel plate and bolted it to the quadrant on the linkage to extend it backwards, this then enabled me to attach the pin for the cable connection facing the other way (towards the carb) , the triangular piece of plate just allowed the cable connector to move backwards and forwards without fouling on the spindle and linkage.   it then all lined up perfectly.
(https://i.postimg.cc/dtKwMfYK/IMG-1209.jpg) (https://postimg.cc/6TzDnYqH)private image hosting (https://postimages.org/)
(https://i.postimg.cc/FHT4LsJ9/IMG-1210.jpg) (https://postimg.cc/yD3tqKP5)
Title: Re: carb
Post by: Dave DND on May 04, 2021, 11:10:08 AM
I used one of these when I had a Type 1 lump in mine
https://www.limebug.com/product/view/1959/roller-throttle-tube-accelerator-cable-guide-25#temp
(https://i.postimg.cc/bYFz25Y3/image.png) (https://postimages.org/)
Title: Re: carb
Post by: mancityjeff on June 12, 2021, 08:03:19 PM
Hi all following on from my issue with my carb it seems that i have the wrong manifold for my twin chock webber that was built with the engine does anyone have a manifold with the bolt attachment on the side so i can purchase the correct linkage or know of a site i can look to purchase one.
Title: Re: carb
Post by: snoopy on June 13, 2021, 08:34:18 AM
Can you weld onto yours or drill and tap it to fit the mounting.
Title: Re: carb
Post by: mancityjeff on June 13, 2021, 01:50:29 PM
Its not something have thought about i would sooner get the correct maifold with linkage that would be best for running correctly
Title: Re: carb
Post by: mancityjeff on June 13, 2021, 06:25:33 PM
all sorted
