Beach Buggy Help Zone => Beach Buggy General Help => Topic started by: mk4buggy on April 26, 2021, 12:11:57 PM
Title: Dry flake spraying
Post by: mk4buggy on April 26, 2021, 12:11:57 PM
I'm going to dry flake a trailer, I have the correct gun, and I'm going to hire a  compressor, does it matter what size compressor I get.
Title: Re: Dry flake spraying
Post by: Roadrunner on April 26, 2021, 12:47:04 PM
Compressors are measured in CFM (cubic feet per minute)
Normally your spray gun will have that as a reading.
For the Flake King 1050
Quote
This particular gun requires a normal size compressor to run and the minimum specification that we recommend would be a 2 CFM and 3 psi up to 20 psi.
You will also need to look at the spec of your gun you are using to spray your lacquer.
Post by: mk4buggy on April 26, 2021, 02:35:40 PM
Cheers Gordon, that clears it up, I thought I could get away with a 2.5 cfm compressor, didn't fancy lugging a large compressor home
