Beach Buggy Help Zone => Beach Buggy Body and Chassis Help => Topic started by: Halliggye on January 14, 2019, 10:17:56 AM
Title: Framehead replacement.
Post by: Halliggye on January 14, 2019, 10:17:56 AM
I'm now looking at keeping my chassis but the framehead is pretty bad, I'm happy with welding and making up a jig etc etc.. My question is regarding the pattern panels: they look shocking quality wise; visibly distorted and welding that looks like it was done by a blind hedgehog....in a bag.
(http://www.vodouautokits.co.uk/Images/framehead.JPG)
Which is the least rubbish / closest to OEM in your opinions?
Title: Re: Framehead replacement.
Post by: Roadrunner on January 14, 2019, 04:00:03 PM
I would talk to https://www.customandcommercial.com
Their stuff is normally pretty good
Post by: snoopy on January 14, 2019, 07:55:11 PM
you will be lucky if the axle mounting bolts line up. If Gordons suggestion is no good a cut the rust out and fit new metal in the original is best.
Flags will tell you his aftermarket frame head horror story and let you know his valued opinion.
I have one on mine but did a lot of welding and tweaking before fitting as I had a 1302S floor.
Post by: Roadrunner on January 14, 2019, 08:16:46 PM
Other option is to talk to Lee @ Volksmagic http://www.volksmagic.com (http://www.volksmagic.com).  Nice guy and has lots of experience with chassis restoration and modification
Post by: Halliggye on January 15, 2019, 02:31:31 PM
Hmmm strikes me that it'll be cheaper to just write this chassis off and find a replacement.
Thank you for the replies.
Post by: Roadrunner on January 15, 2019, 02:59:26 PM
I would suggest selling it on then.  There are a finite number of these old chassis.
Post by: Flags on January 15, 2019, 03:16:45 PM
I think there is only 1 quality out there which out of the box are shocking quality but with a bit of work they can be made to work.
Before fitting I'd recommend bolting it to a beam to check the alignment of the bolt holes and if not good send it straight back.
If they are ok remove any seam sealer and check/reweld anywhere it needs it then it should be ok, I had 1 that the front face was coming away and 2 of the threaded tubes had broke away.
Post by: Dave DND on January 15, 2019, 03:24:50 PM
I`d be looking at the V5 wording BEFORE thinking about selling a chassis these days
The metalwork may be easier to replace than the paperwork  ;)
Post by: Manxdavid on January 15, 2019, 03:41:52 PM
I'm pretty sure there's only one company making these and firms are just putting their own stickers on them. For such a complicated piece I guess we're lucky that anything is available as a repair panel, even if they do need a bit of 'fettling'. As Flags says, they do work but allow for a couple of hours grinding, welding and re-tapping threads. Any alternative chassis that you find will more likely need or have had work done in that area anyway.
Post by: Roadrunner on January 15, 2019, 03:58:25 PM
Quote from: Dave DND on January 15, 2019, 03:24:50 PM
Wording doesn't matter if it's a LWB being built or for that matter is it going to replace a chassis on one of those metal bodied things, you know a Beetle ;)
Post by: Manxdavid on January 15, 2019, 04:22:38 PM
Quote from: Roadrunner on January 15, 2019, 03:58:25 PM
Wording doesn't matter if it's a LWB being built.
In theory yes, but I'd still keep dealings with 'them' to a minimum if at all possible. I still recon they could give you a whole heap of headaches if the wrong person opened your envelope. :-\
Post by: Dave DND on January 15, 2019, 04:30:43 PM
You forget that a lot of LWB ones still say Convertible on them  :-X
Post by: Manxdavid on January 15, 2019, 05:16:53 PM
Quote from: Dave DND on January 15, 2019, 04:30:43 PM
It is what it says on the tin then, a converted convertible VW, IMHO of course!  ;-)up
Post by: Zip Buggy on January 15, 2019, 05:30:18 PM
I thought "convertible" was OK,  am I wrong Dave?
Post by: Manxdavid on January 15, 2019, 05:39:02 PM
Quote from: Zip Buggy on January 15, 2019, 05:30:18 PM
No, it's fine, the last lwb I built was inspected by a DVLA engineer at a VOSA test centre and he got the description on the V5C changed from saloon to convertible, buggy wasn't on his list at the time (5 years ago). He also had Beetle deleted from it so it just read 'VW Convertible, 1970'.
Post by: Dave DND on January 15, 2019, 05:53:32 PM
VW Convertible is a brilliant one to have as it does not distinguish between LWB and SWB, so if thats what the V5 said, then I personally would be repairing the chassis, as the blood sweat and tears are insignificant compared to getting that wording from the powers that be.
So, to put us out of our misery, what does the V5 actually say?   ???
Post by: Paul1953 on January 17, 2019, 01:13:56 PM
Try all you can to avoid the "aftermarket" frame head. It is rubbish and not fit for purpose. You will often see on ebay chassis offered for sale with the frame head chopped off. This is almost certainly because someone has needed a decent original section and has found something usable.
Post by: Halliggye on January 24, 2019, 08:29:22 PM
Quote from: Dave DND on January 15, 2019, 05:53:32 PM
Mine says "Beetle Saloon" I'm intending to build a LWB and to get it changed if possible.
Post by: snoopy on January 25, 2019, 07:42:48 AM
A re-body so a lwb with all original spec running rear will get a change to convertible like Matts Manx recently. Time to start a build thread  ;-)up
