Fuel gauge.
Started by Marknloopy, July 23, 2016, 03:44:09 PM
Marknloopy
1961 Baja GT in blue.
When we got our buggy we were told the fuel gauge did not work and when I took the speedo out I found the 'vibrator regulator' was missing.
The problem I am having is finding one as they appear to only be found at the end of rainbows!
Has anyone got one on here got one I can buy?
       Mark 😎👍
Grumpy and Loopy 😎👍
Doon SWB No.1 & No.2
Hi Buddy,
I have one here. Private message me your address and I'll post it out.
just throw a donnation into the Pier Pressure justgiving pot
https://www.justgiving.com/teams/pierpressure2016
Marknloopy
Hi
I have inboxed you our address and will make a donation.
Mark
Grumpy and Loopy 😎👍
Marknloopy
Hi Chad We have made a donation and hope to see you at Aberystwyth pier as we plan to go to Borth the day before and then if we can keep up we will follow you back to Chester.
What sort of time do you recon you will arrive at Aberystwyth ?
Grumpy and Loopy 😎👍
Hi Mark. Thanks for the donation.
I couldn't get to the fuel regulator today as took my engine out to replace the gearbox oil shaft seal. Only to find I had the wrong replacement part. So Buggy with engine on floor behind means I can't get to my electrical bits on the mezzanine in the garage. Hopefully all sorted tomorrow so I can get the bit out to you.
I have put the detailed daily schedules up now on the Pier Pressure section on here. Aberystwyth is the first pier we go to and should be there about 12:30 ish.
Will be great to have you with us and we will only be cruising along so no problem keeping up.
Marknloopy
Yeah I know what it's like to try to find stuff when you have a garage full...I currently have a goldwing trike in bits, a Honda ER 500, a Honda ST 1100, and of course the beach buggy. Today's job was fitting a rack on the back for carrying camping gear then I started adding 'pimp lights' around the body for night time posing...I love electrics!  ...lol 😎👍
Grumpy and Loopy 😎👍
Marknloopy
Hi Chad
The regulator arrive this morning so once I have finished the huge list of jobs Loopy has lined up for me I will go and fit it and put my dash back together.
Once again thank you for sorting one out for us and we look forward to meeting you on the pier trip!
       Mark
Grumpy and Loopy 😎👍
