carpet to fit
Started by mancityjeff, June 06, 2016, 12:22:10 PM
mancityjeff
lwb 1971
I want to replace a bad fitting carpet in my lwb but how do you go about cutting carpet to mold the shape at the end of the tunnel, or is there a cheap version out there to buy, had a look on line full set around 200 to 250 any advice appreciated.
mancityjeff
I used hard foam padding shaped and glued with the carpet laid over it in the past.
Big GP
Try rugs for bugs, if you speak with Nick and send him templates he can do a full set including a tunnel carpet for around £100
madmatt
sidewinder
I posted about a month ago to chinaboy,should be in buggy tech section somewhere. ;-)up
The more you know,the more you know you don't know
madmatt
sidewinder
May 10,wall to wall carpet  :D
buggypete
to do buggy carpets i use 2 types of carpet,for the tunnel i use the soft felt style and the main floor use the plastic/rubbber backed type,always available at kit car shows
