Van box or bell housing
Started by recon1, May 29, 2016, 01:06:55 PM
recon1
Bugle, Fugitive, Kingfiher Kommando
Hi all
Anyone got a knackered old van box or a bell housing off one. Need a part from a bell housing.
ruben
hotrod sportscar
what do you need? i've got one on the engine stand, not used for running.
recon1
Hi
In the hole that the input shaft passes through is an oil seal that knocks out from the gearbox side. Behind this is the oil control scroll, this is the part I am looking for. It knocks out from the gearbox side after the oil seal is removed. It is a bit thin so it is best to knock it out using a block of wood.
The one I have was put in a safe place and has managed to disappear.
If you have one that would be great.
Rich
recon1
