Wiring in general
Started by simon-dubman, May 29, 2016, 06:31:23 PM
simon-dubman
Hi all over past few daysyou may have seen a coup,e of posts about wiring  >:(
Ok so time to start again. Mounted fuse box..
Light switch 2 x 30 continuity tested ok, X has no continuity when anything done to switch. So this means.. The live from alt/batt in 30 then other 30 to ignition.. The x to fuse box. No lives at the fuse box..  This is a new switch I know it works as I swapped it over from the beetle.
So do I put a jump cable from the 30 that works to fuse box?
Once I have this damn switch linking to fuse box with live I think I should be ok..
What's the norm? Really annoying me now but it won't beat me... Advice please peeps best method??
Doon SWB No.1 & No.2
Hi Simon.
I can help you but on hols at the minute and difficult to type out the correct wiring diagram on a phone.
Will be back next Monday if tats not too late?
simon-dubman
Hi Chad
I have made up a jump cable. And I think I have Sussed it out. I am home this week then I'm away on business the following week. Thanks for the offer. If I don't manage it I'll be back on  :'( :'( :'(.
Cheers
