Wanted - GP Mk1 Dash brace
Started by Tricked, October 08, 2015, 12:39:07 PM
Tricked
GP MK1
Anyone have a Dashboard/steering column brace for a GP Mk1 or knows of a company that sells one?? Ta
No Worries!!
Krug
Try Flatlands
http://www.flatlandsengineering.co.uk/fle/fle_bgkp.htm
BK01   Steering Column Support, designed to fit most body styles, 3 way adjustable, also braces dashboard to bulkhead, all mounting bolts included.   £137.50
Tricked
GP MK1
Thanks Krug,
Looks like I'm going to have to open an account with flatlands £££
No Worries!!
Luddite
GP2 SWB / GT LWB
IIRC, the GP one's a length of tube with a couple of bits of strip steel welded on the ends.  Just as easy to make something up I reckon, you'll probably end up modifying the 'proper' one anyway.
buggypete
original gp one were very simple,2 tubes and a bit of flat bar easy to make,remeber gp,are differant width to manx/manx derrived buggys.just make your own as you will be able to put the coloumn and supports exactly where you want them ;-)up
Wilcoivette
GP Mk1
#5
I had a original, but remake it.
Later i made some more strips in it to make it stronger
There are good pics of an original frame on 77atthew's build thread.
