American Racing Wheels
Started by Paddy, October 06, 2015, 06:26:09 PM
Paddy
RIP - 23/06/2018
GP MKII LWB / LWB Doon
As it says + tyres, these were brought a few yrs ago for a project i was going to do but things have changed so im selling stuff off. They owe me well over £700 and were  professionally polished when i had them, but as you can see they do need a polish again. i didnt have the middle inner rim polished as i was going to paint them the colour of the buggy so if you want them they will need a buff.
Chevy pattern but they have slotted holes as you can see. Will fit on adapter plate on 4 stud and a modified front spindle
Looking for around £650
Paddy.
Also have other stuff to put on when ive sorted the shed out
Rest In Peace - You will be Forever in our thoughts . . .
Paddy
RIP - 23/06/2018
As not to confuse they were 2nd hand and were off an old American car. they must be around 20 odd yrs old. So old stock  ;-)up
BuggySteve
Manxter 2+2 Dualsport
Paddy
The wheel width is measured from inside the rim lip.  That's where the tyre sits. Just a heads up bud ;-)up
Manxter Dualsport
Quote from: BuggySteve on October 06, 2015, 11:03:03 PM
Paddy
X2...WHS^^^ It's hard the tell the widths the way you're holding the tape.
Paddy
RIP - 23/06/2018
O/D 200, thickness of wall of rims 11mm on 205 tyre
O/D 225 thickness of wall 10mm on size tyre 225 as picture
Paddy
RIP - 23/06/2018
P.s thats eash side wall thickness just incase anymore confusion...
What are the true widths in inches (inches are still the usual standard for wheel widths and diameters)?
Paddy
RIP - 23/06/2018
Errr. dont take this the wrong way but are you taking the pee now ?  ???
200mm - Thickness of wall 22mm = 178mm = 7 1/16"
225mm - Thickness of wall 20mm = 205mm = 8 5/64 "
Anyone that needs a converter that can not do it on a calculator -
http://www.metric-conversions.org/length/millimeters-to-inches.htm
Quote from: Paddy on October 07, 2015, 10:40:15 PM
Not at all, it's just that they're American wheels and I thought they'd sell better if posted in the nominal sizes that they were made it. 8x15 and 7x14 then?
buggypete
do you have the nuts as the mounting holes have been uniluged so differant threads :-\
Paddy
RIP - 23/06/2018
Sorry no nuts as i never fitted and i dont know what uniluged is ?
Machine 7 do all available conversions and nuts i believe.
Paddy
RIP - 23/06/2018
Nice one Dave  ;-)up
Paddy,
As a person who buys way too many wheels that is possibly healthy,  :-X  I have to agree with the others about your measurements.
Diameter is easy and is in inches   ;-)up
Rim with is not the actual width if the rim itself as that would be too easy, its the inside edge to edge measurement where the tyre sits, and this too is in inches
Now you have your head in imperial mode, the PCD is generally stated in mm, but as yours is Unilug, it kind of suggests anything goes as the holes are elongated.
Might help with the sale if measurements are the same type as the ones people are searching for   ;)
Hope this helps  ;)
Quote from: Dave DND on October 09, 2015, 05:48:56 PMNow you have your head in imperial mode, the PCD is generally stated in mm
On most European things sure but with American wheels off an American car I'd stick to imperial too, typically 5 on 4 1/2" for Ford and 5 on 4 3/4" for Chevy (except for larger station wagons...Ben ;-)up).
