Pedal assembly help please
Started by moggy, March 14, 2015, 04:12:37 PM
moggy
How do I split the assembly so I can fit it to the chassis please
HUDGE BUGGY
GP Mk2 Super Buggy LWB
On my 1970 onwards pans they normally go in fully assembled the hard bit is getting the clutch cable hook into the tunnel hole and folding the pedal assy down to the pan, the already fitted accelerator shaft pushes through fully when it is down.
Quote from: snoopy on March 14, 2015, 08:01:07 PM
WHS^^^. Hold the clutch cable loop onto the hook with a thin cable tie (it'll just snap off when you start using the clutch). Don't be tempted to cut an access hole in the tunnel as this will seriously weaken the chassis structure.
