manifold
Started by mancityjeff, February 19, 2015, 07:20:50 PM
mancityjeff
lwb 1971
H,i I have just bought a new manifold for my twin port 1300, so my question is what do I do with the little pipe on the manifold, do I have to connect something to it or blank it off,
mancityjeff
Unless you're using a standard air filter just blank it off.
mancityjeff
lwb 1971
I think I have a pancake filter
As David says the one on the manifold down pipe needs blanking off as it is not used on the pancake filters.
mancityjeff
lwb 1971
Say I cant find my pancake what should I use instead as a good start.
Quote from: mancityjeff on February 20, 2015, 06:07:59 PM
Your pancake probably got eaten last Tuesday...a crepe or a waffle would do the same job... ;D ;D ;D
Nice timing there  ;D ;D ;D ;D
It depends on the body clearance above the carb you can get cheap pancakes actually there is a new unused one in the shed I paid £12 from machine 7 for but you can also use a cone filter which will be better and can be fitted with or without an elbow.
mancityjeff
lwb 1971
Ok good feedback thanks great help,
