irs gearbox, temp gauge etc
Started by kirkyj, November 24, 2014, 04:31:02 PM
kirkyj
prowler
irs gearbox  am code 1300 box £150
oil temp gauge blackout, analogue needle style when on, never used £10 posted
an fittings, to accept 20mm outside diameter pipe x4 new £8 posted
meyle track rod ends ball joint all new, long rod inner  with s damper bush upto 67 £10 posted
short rod inner upto 67 £6 posted
later 67 onwards outer £6 posted
fuel pump £9 posted
pair of rear brake hoses 250mm irs new £9 posted
Alternator regulator & brushed, brand new never used 55amp/70 amp with terminal £25 posted
