sandrail build
Started by 93fxdl, October 17, 2014, 07:45:11 PM
93fxdl
sand rail and manta ray
Decided to get back to the sandrail,  made a to do list, brakes, rear suspension,  wiring, and lots of odds and ends.
Started by buying  a land rover steering rack
So can do a cheap rack conversion
Looks hopeful,  will need to pull the worn steering box out and start fabrication on some mounts
Ttfn Glenn
bajaowa
Is that power'd steering? Are you gonna power it up?
You may find the landrover rack to wide and get some strange angles in the steering and limited turning.
93fxdl
Quote from: bajaowa on November 12, 2021, 09:23:40 PM
It is a power rack but first mod is to remove the hydraulics so it operates as a manual rack
Ttfn Glenn
93fxdl
Quote from: snoopy on November 13, 2021, 08:35:14 AM
It's a freelander rack so has the steering arms mounted in the middle like the popular polo rack  but being landrover, has tha advantages of being cheap and easy to get
Ttfn Glenn
93fxdl
Better picture of the rack
Did a little bit of fiddling with the rail today, pulled the rear drums off and binned the shoes and cylinders as everything was oil soaked from it's time on the rotisserie
Ttfn Glenn
IDA
Mk2 Rat and LDV
Mercedes a class electric pump ;-)up and keep it full pas..
93fxdl
Quote from: IDA on November 14, 2021, 10:51:09 PM
Trying to keep it as minimalist  as possible,  also with a light rail, power assistance would most likely be overkill.
Over the next few days, hope to strip the rack and remove all the hydraulics, might even be able to reduce the width of it
Ttfn Glenn
93fxdl
Forgot to say, minimalist is the budget target also
Current spend
Complete rack assembly  £36
Mk5 golf column  £9.99
If I dont get caught out over incidentals, I hope to get it done for less than £100
Or if it doesn't work out, I will waste less than £100
Ttfn Glenn
bajaowa
Or have less than £100 of spares to sell. ;)
93fxdl
Quote from: bajaowa on November 15, 2021, 09:36:21 PM
Or knowing me, less than £100 of unfinished project
Ttfn Glenn
Worth a try for £100 if it works sell some kits for more money.
93fxdl
Quote from: snoopy on November 16, 2021, 07:49:36 AM
Not planning on making kits for sale, but putting the info up for anyone to copy if they want too,
If I can get it done for under a ton, could  be cheaper than a new steering box, also if successful I will be converting my manta buggy, as it's king and link pin with a badly worn steering box
Ttfn Glenn
93fxdl
The golf column has arrived, tomorrow,  hope to get the rack stripped  and start some more test assembly
Ttfn Glenn
