wiper arms
Started by beach buggy joe, September 13, 2014, 03:22:08 PM
beach buggy joe
got some arms to go on my buggy,but they seam to short,they are the domed type with slots running down them,was wondering wether the camper ones would fit,as the motor is all fitted and the dash is molded to bonnet and all fitted so dont want to take apart. jon
For superglimmers buggy I used 4 arms to make two long ones with application of the mig welder or look in recommended suppliers you can get adjustable length ones.
buggypete
adjustable wiper arms usually have british leyland spline fitting that wont work with vw spindles,either use a fiat wiper assembly(127/500?)or you can adapt using land rover wiper ada ptors.
Good new Pete they do 1/4 inch collet fitting that clamp on a spindle that should clamp on the 6mm beetle shaft or it may ned a thin packing if it is loose.
