Various parts - Beetle / Buggy /Splitty
Started by Buggybaggy, September 07, 2014, 05:37:10 PM
Will need to add postage to these prices, or arrange collection.
Pair of unused splitty wiper blades £10.
Splitty gear lever extention (No domed bolt with it)  £5
Twin port inlet manifold from a 1600 - without end sections.  The heat risers are reasonably clear, such that I passed length of cable through, as you can see.
5 hub cap clips.  Were bought for a splitty, not surt if they are the same size as Beetle ones?!   £1.
(More to follow.....just been call for tea!!)
Some more bits.............
Beetle hazard switch.  Working order unknown.  £5.
Light switch. Working order unknown.  £5.
Cable shortening kit.  £6
Oversize fuel tank outlet pipe £4.
5 Unused wheel bolts. £3.
Ignition barrel -  no key!   £2.
All in Leeds   ;-)up
Mr Twister
Hi Buggy baggy
Can I take the wipers, gear lever extension, cable shortening kit and hubcap clips please.
I make that £22 but correct me if I'm wrong.
Will PM my address.
Please let me know how much postage is on top and how you want payment.
Cheers
Tony
If life was meant to be easy, Michael Angelo would have painted the floor.
Mr Twister - you have PM.
CORRECTION TO ADVERT
The tank outlet pipe is standard size I think.  Certainly not the 8mm I thought it was  ???
SR Buggy
GP Mark 1
Hi, I would like the Fuel Tank Outlet Pipe.
I have sent a PM to you.
ANOTHER CORRECTION!
Inlet manifold isn't showing a price....... wrist slapped!! (Thanks H  ;) )
Wanting £20 for it.
