Buggy parts wanted
Started by Supergimmer, June 01, 2014, 09:21:23 PM
Supergimmer
Jas lwb
Hi
I need loads of really random spares hope you have them
Steering damper
Ignition barrell and key
Handbrake cable clamps (to rear back plates)
Accelerator linkage cover (on tunnel)
Complete windscreen wiper setup (for buggy so need it all)
Fuel pump spacer/mounting
Clutch cable conduit bracket to gearbox
Hope I can get these bits sorted
Testa
In order
GSF
GSF
Possibly GSF but defo Vw heritage
???? May be make your own
eBay and mini classic arms with blades
I think I have the black backer lite spacer
Not sure but custom your own
Testa
Supergimmer
Jas lwb
Update on what's needed...
Handbrake cable clamps x 2
Ball joint nuts x 4
12mm spring washers or lock nuts x 10
Clamp for cable (nipple) on carb x 1
Handbrake cable nuts (domed) x 2
3 mtrs copper fuel pipe
clips for fuel pipe into chassis x 6
Linkage cover LHS tunnel for throttle cable
Windscreen wiper complete
Ignition barrel and key
Windscreen and frame for jas LWB
clutch cable conduit bracket on gearbox
Fuel tank filler and tube (already have tank)
Body gasket for buggy
Needs to be as cost effective as possible
Thanks for help
buggypete
can do most of that,but dont use copper for fuel pipe use cunifer as it doesn,t work harden(vibration will cause cracks/leaks/burned buggy?)07855 542195,if your going deva could bring most stuff
buggypete
have you made your mind up which wiper motor you are going to use,i,d like the spare one back.ta
ben_w
I can possibly sort the handbrake cable clips.
As for the filler and tube, are you using std stuff? I have a std tube .....
Supergimmer
Jas lwb
Have got all bits needed.
Only bit now needed is a fan cover.
