Gearbox adapters
Started by pepsi81, May 14, 2014, 10:52:13 PM
Probably a question for Snoopy but here goes,
Anyone got alternative engines to vw air cooled, if so how do you adapt the gearbox or are you all using a different box.
Thanks for any reponses.
Most adaptors are a simple flat plate with spacers on the mounting bolts holes to suit the irregular mounting bolt positions. The flywheels are beetle 200mm size with the inner of the donor crankshaft spaced backwards or forwards to get the distance correct for the clutch to work.
Some like the ford pinto required the gearbox input shaft changing to suit.
Mine has the 2l fiat and a standard 200mm clutch.
Hunter
SDBC Moderator
CTR
These guys seem to be well used..
http://www.kennedyenginc.com/Pages/default.aspx
H
Thanks guys, that certainly food for thought
ben_w
Crown Mfg do a very nice adaptor place for the Corvair engine... :D
Zebethyal
'65 SWB Volksrod Mk III
Quote from: Hunter on May 15, 2014, 08:56:04 AM
H
I used to be their only UK distributor before I largely stopped selling parts :)
buggypete
got an adapter plate for vauxhall single overhead cam(cavalier/astra)£40
