new carb problem
Started by bills, February 25, 2014, 07:41:30 PM
bills
Predator
Yes it has a 009  and I have blocked it off with a pipe and bolt.  I have not been pumping it but will take the air filter off and check if the pump is working.  I will also check the working of the choke
Thanks for the help
bills
Predator
Thank you all for your help,  must have been old fuel somewhere in the lines, now starts,  it runs very fast at idle so will try and work out how to adjust.  great to hear it running again
bills
Predator
The buggy has never run so well , should have gone for a single carb years ago  next problem is the brake lights are on all the time, i expect after being sat  for so long the switch is clogged,   any ideas?
Quote from: bills on March 01, 2014, 08:13:56 PM
Check the m/c pushrod's got clearance, it needs a gap of iro 1mm. Also the pedal could be sticking a bit, nothing a squirt of 3 in 1 couldn't sort out.
