Beetle front beam
Started by Barneyboy1, December 29, 2013, 05:22:24 PM
Barneyboy1
Hello everyone, I am very new to this forum and to the buggy scene for that matter, and have just run into the problem of needing a front beam for my buggy project and some useful info from any one that knows much about them, thanks for reading
GBHgpJON
GP MK1 Superbuggy
Hi....what year is your buggy for a start?
They differ between link pin and ball joint........
Barneyboy1
Very sorry forgot to say, it's a 1970 , thanks
GBHgpJON
GP MK1 Superbuggy
Ball joint then.  ;-)up
Do you need just the beam or beam with suspension arms/spindles/drums or discs?
What is the problem with the beam, sometimes it's better to repair an O/G one, rather than fit a repro one. Assuming its the dreaded rot thats caused the problem!
Barneyboy1
The main problem is I don't have one atall, this is the first ever buggy for me and I am learning by the minute, I have a 1303 s as my main doner , so first thing is shorten it for the shell and try to source a front beam, sorry if I sound stupid, and thanks for your time
GBHgpJON
GP MK1 Superbuggy
#5
Hang on, doesn't the 1303s have struts?.......no good for a buggy :(
Unless you change the Frame head............
Altho the 1303 wasn't introduced until 73.......are you sure thats what you've got?
The 1302 was earlier with a flat screen, is your screen flat or curved?
Barneyboy1
The chassis I am using is a 67 , and the 1303 is a doner for the engine and majority of running gear, sorry again should of mentioned this
GBHgpJON
GP MK1 Superbuggy
#7
Phew!........ ;-)up
Will you be converting the 67 to use the 1303's IRS?
Barneyboy1
That was my plan but what would you recommend
GBHgpJON
GP MK1 Superbuggy
#9
Definately.........if you need a jig, we have one available to borrow
over on www.bajaclub.co.uk or as we are affectionally known......the muddy side!
Barneyboy1
That sounds like a fantastic offer and I appreciate all your help and info so far, do you have any sources for a front beam
GBHgpJON
GP MK1 Superbuggy
I dont know of any secondhand ones at the mo, but I'll keep 'em peeled!
No worries about the help, thats what these sites are for!......... ;-)up
Barneyboy1
Thank you again, it's been a long time since I've been on a forum and I forget how much of a close community it is
GBHgpJON
GP MK1 Superbuggy
I've stuck a wanted add on the Baja site for you as well........ ;)
I'm sure between us we'll find one.........if not theres always the usual online sites for repro ones..... ;)
Chris_e_86
Fibre fab
I have a og bj beam that's in need of minor repair has leaves in it the arms are no good can't get grub screws out though should be salvageable will get pics
