IRS weld on brackets
Started by ben_w, December 01, 2013, 09:29:03 AM
ben_w
All,
Think this might be a go so after a pair of the weld on brackets if anyone has some please?
Cheers
Hi Ben for £30 ish they are crap best cut some proper ones out of an irs back end and weld them in.
brummie_steve
Hi ben I used this type can't remember where they came from but as snoopy says they're not good
I ended up slicing them in two as the holes didn't line up fitted the inner part first then the outer part this also made it  easier to get a good weld on the inner bracket  hop that makes sense
