oil pump and AD case and main bearings
Started by snoopy, January 31, 2014, 03:14:27 PM
used parts, high capacity oil pump only identity mark is a D on the inner casting to suit 3 bolt cam, 15mm deep body, internally no wear and only slight signs of gear rotation on cover plate has slight wear on opposite thrust corners of drive peg complete with studs £15 posted.
AS41 AD engine case 0.5mm line bore done and fly cut rear thrust of 2mm so bearings available, rear main bearing pin has slight movement due to previous build with standard thrust bearings very useable and pin could be made 100% solid just needs a good clean. £35 + p & p £10
set of main bearings +0.5mm for line bore and standard thrust and crank still in box used for a dry build never run £15 posted
only for sale as I have no reason to build another motor.
paul
ctr
Hi Snoopy, If they are still available, I will take the engine case and bearings off your hands, could sort out  at MBC meeting this week
Hi Paul, the bearings do not fit the case as they are not the machined thrust but standard ones, I will bring it over and you can have a look.
paul
ctr
