Transaxle
Started by Mudman, September 01, 2013, 11:12:09 AM
Mudman
Mk 3 Volksrod
This follows on from my transaxle drain/fill thread...
i need a transaxle for a 1300 engine fitted to what might be a '72, or a fair bit older chassis.  I would have thought that it would need to be complete as it is replacing a very old split case axle.
have a word with Pits he has a few any size will do you are not stuck with just 1300 but any 1966 to 72  although you can swapp nose cones so a post 72 will fit (your split case is no good as a donor) and that has the supported clutch bearing that needs the later clutch cover.
