Rubber grommets
Started by Manxrod, September 01, 2013, 03:48:10 PM
Manxrod
Myers Manx. MK1GP swb
Does anybody know a good supplier for rubber grommets to go through fibreglass bodies for the wiring . Thank you.
make it if you can.
Richyc
Jas Lwb
i found i couldn't get ones wide enough, so i used the rubber lining out of P clips and cut it to size, though it wont seal the hole it will stop the cables from rubbing.
hopefully someone else will have a better solution....
MUST refrain from taking it apart.....again.....
Hunter
SDBC Moderator
CTR
Manxrod
Thank you  ;-)up you would think somebody would make them :-\
make it if you can.
