gear stick
Started by mancityjeff, August 06, 2013, 06:46:41 PM
mancityjeff
lwb 1971
Hi
I have a 1300 lwb and would like to change my stick, I feel I have a lot of travel and have herd that a change of stick will limit the travel and give better change, what is a good stick to look at and from who.
Also, while you are at it, make sure the bushes on the rod in the tunnel are sound. Certainly the quick shift plate or gear stick are what you are after, but its important the bushes are fine to ensure good positive changes.
#3
WHS^^^ Thoroughly check the nylon bush in the tunnel just to the rear of the shifter, and the coupling at the back onto the gearbox.
If there's play in either a new shifter or quickshift kit will not work properly.
If you do feel the need for a nice aftermarket shifter there's a very nice Scat one on eBay at the moment...lol...item no. 190880745290
mancityjeff
lwb 1971
Thanks for the help,
Can I check the bushes in the tunnel by looking or do I have to take gearbox out or just remove the gear stick.
Hunter
SDBC Moderator
CTR
Hi Mate,
Big GP (Gary) has this for sale in the parts section.
http://www.beachbuggy.info/index.php/topic,2504.15.html
H
Quote from: mancityjeff on August 07, 2013, 12:24:24 PM
Just take the gear lever out to check the front bush and the cover at the rear to check the selector knuckle on the end of the gearbox.
