Photobucket
Started by pepsi81, July 25, 2013, 11:27:39 PM
 Can i use photbucket on a Samsung tablet. Managed to upload but can't susshow to transfer to a topic on theforum.
Thanks in advance Paul :'(
Big Clem
66 prowler
Hope some one can help cause ive not worked it out on mine either  :-\  ;D ;D
Mikeohope
Doesn't each photo have an IMG code which you just copy and paste in to your topic text???
Mikeohope
If you click or select the photo doesn't a box appear with a selection of codes that you can use? One of those codes should be the king code. Samsung tablet uses android so it should be ok.
FAO Big Clem,
Finally managed photobucket using a Samsung tablet.
1. Upl8ad images to photobucket.
2. Follow Andy's advice in the newbie section.
3. To copy, highlight the img link for a few seconds, this shouldmbring up an option to select all, then select copy.
4. Open up a new topic in the forum, then highlight area this will bring up a paste option.
5. You need to select preview to view images.
Its a bit of a faff on a tablet, but does work..
Best Paul.
