disk brake bolts
Started by muzzy01, June 23, 2013, 11:32:06 PM
muzzy01
lwb gt 2LTR 914 /lwb jas
lads ive managed to pick up a front wheel disk brake conversion but it didnt come with any bolts to put it all together, theres 4 either side they are high tensile has anyone got a set they want to sell please
MUZZY
muzzy01
What size are you after?
I`ve got 10 brand new M14 x 1.5 x 28mm thread with a radius cup bolts left over
muzzy01
dave its the bolts that bolt the calipers to the spindles m8,
MUZZY
muzzy01
anyone know what size they are so i can try buy new please
MUZZY
Hi Muzzy, if you get no joy tonight, I'll take one of mine out and measure it for you!
moss
May have some but won't be able to check till Tuesday
I haven't looked, but from memory M8 sounds right, and a good quality high tensile (typically Black in colour) bolt will do the job just fine :)
targed
They're not m8 Peter. Can't remember exactly what they are, but m10 fine rings a bell. However bearing in mind that this is a safety related thing, don't pee about, just buy the proper ones! All the usual parts places stock them, as do gsf.
Jon
Jon
Mmm, I should have had a look.... Yes mine have a 17mm hex head, so are 10mm.
Of course get the correct size and shank, ie not threaded all the way up to the head
Peter  ::) :-[
muzzy01
just wrang gsf they dont do bolts
MUZZY
muzzy01
think now sorted 10mm 17mm head
MUZZY
targed
http://www.veewee.co.uk/index.php/655vg0290
Gsf are talking boll...s! They list them, on their website!
Just beware that they're a fine pitch iirc and not the standard course thread.
Jon
muzzy01
they are talking rubbish then, but going to a local place who do high tensile bolts said they got them in stock just have to take the caliper down to them to measure thread, im freinds with owner so ill get them loads cheaper, but thanks for the heads up mate
MUZZY
